Converting text to outline
Post by andrew » Sun Sep 08, 2013 4:39 pm
From a QCAD user:
Could you tell me if there's a way to insert or convert text to an outline?
I want to use Qcad to output to a laser cutter to cut out letters.
Re: Converting text to outline
Post by andrew » Sun Sep 08, 2013 4:42 pm
- Select the text(s) to convert
- Modify - Explode
Note that we also have a CAM add-on for QCAD which produces for example G-Code from all entities including text outlines.
More information about QCAD/CAM:
http://qcad.org/en/what-is-qcad-cam
Online ordering:
http://www.ribbonsoft.com/shop/product. ... roduct=193
