Isometric bitmap
caigner
Isometric bitmap
Post by caigner » Tue Jun 17, 2014 3:37 pm
Hi!
I just created a little box in isometric projection and tried to cover its sides with an image of wood, but I couldn't make it happen.
Is it possible to use the isometric tool with images?
Christian
QCAD Pro on Gentoo Linux
Re: Isometric bitmap
Post by andrew » Tue Jun 17, 2014 3:44 pm
caigner wrote:Is it possible to use the isometric tool with images?
No, that's not possible at this point. The DXF/DWG file format looks like it might support this (sheared images), but I'd have to look into this first to be sure.
caigner
Post by caigner » Tue Jun 17, 2014 4:09 pm
Filling an area with a bitmap would also be nice. :-)
Moderator / Drawing Help
Post by Clive » Wed Jun 18, 2014 9:19 am
caigner wrote:Filling an area with a bitmap would also be nice. :-)
Nice ideas, don't forget to add these to the bugtracker (used also for feature requests) so they don't get forgotten about :wink: .
http://www.ribbonsoft.com/bugtracker/
