What are the benefits of SVG ?
About the creation of SVG items.
Moderator / Drawing Help
Post by Clive » Fri Jun 20, 2014 10:05 am
To get this topic started, I'll throw out this question to the QCAD community.
What are the benefits of using SVG ?
Carolus
Re: What are the benefits of SVG ?
Post by Carolus » Wed Jan 06, 2016 9:46 pm
QCAD does not facilitates export as .EMF .WMF etc. Via .SVG export one can use another program to accomplish these file formats. I used inkscape as an interface.
But thereby it turns out that the SVG export of QCAD is not right. In my drawing there are texts. These texts are in the SVG file, but without there coördinates. So they do not appear in inkscape. So is this a bug?
I upload the .SVG file.
AansluitSchemaInternetThermostaat.svg
(2.69 KiB) Downloaded 731 times
Post by andrew » Wed Jan 06, 2016 10:37 pm
Carolus: if you are experiencing any problems, please attach always the original DXF file, thanks.
Carolus
Post by Carolus » Tue Jan 12, 2016 10:43 am
Andrew, you are asking me to attach the .DXF file too. I attach the .DXF file and the .SVG file as well.
BUT there is a strange thing: when I open the .DXF file which I saved at 6 jan 16, QCAD opens it without objections, but I don't see my drawing at the screen. What do I wrong?
Originally this drawing was made with the free version. But I bought the professional version and saved the drawing with this version (3.12.4.0)
Thanks for your work.
Carolus
(2.69 KiB) Downloaded 736 times
AansluitSchemaInternetThermostaat.dxf
(98.3 KiB) Downloaded 701 times
Post by andrew » Tue Jan 12, 2016 10:50 am
Thanks. The DXF is definitely empty though..
Return to “Creating SVG items”
