Crash on Rectangle rotate
Redisha
Post by Redisha » Wed Oct 22, 2014 7:01 pm
On a mac with OS 10.9.5 using Qcad 3.6.3 I'm having a problem when trying to rotate a rectangle.
If I draw a rectangle and then select all the lines choose modify rotate and click on the rotation point the program crashes.
Sometimes I get to the box to enter the rotation angle, press OK and it crashes.
Any suggestions anybody?
Thanks,
Adair
Adair Redish
Re: Crash on Rectangle rotate
Post by andrew » Thu Oct 23, 2014 8:28 am
Thanks for your report.
If you are using a MacBook with an internal track pad, this might be related to this known bug which has been fixed for the current 3.6.4 release:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1076
