How to put text beside objects with distance?
massimo
Post by massimo » Fri Dec 05, 2014 7:09 pm
Putting text next to objects I like to have some distance since the first letter always strikes the line. Too bad there is no alignment like this available (future plans?).
So I just add a space in front of the text. The issue is now that after saving and reopening, the trailing space is removed. Why? I also tried with complex text instead of simple. I also did not find a setting for dropping trailing spaces or something. Any idea?
git build current origin/master, Gentoo Linux on amd64
Re: How to put text beside objects with distance?
Post by andrew » Fri Dec 05, 2014 8:38 pm
The stripping of leading / trailing spaces seems to be a bug in dxflib / QCAD Community Edition.
Bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1139
[moved topic to QCAD Community Edition forum]
massimo
Post by massimo » Sat Dec 06, 2014 9:59 am
Thanks for filing the bug report.
Watching and voted...
