Two newbie questions
sfmac
Post by sfmac » Sat Sep 24, 2016 4:12 am
Just became a user of QCAD. Finally found a 2D cad program worth using. Just have a couple of questions.
1) Is it possible to set the size of the default viewport? I work with very small models and only need a viewport 24 inches (x direction) and 12 inches (y direction. Currently would have to zoom in every time.
2) I have tried to cancel the 'trial' displays for CAM and QCAD PRO. I click the "Remove " button for both but they just return when I boot up. Is there a way to permanently turn them off?
Apologize if these have been answered before but didn't find in forum. Thanks in advance for assistance.
Mac
Re: Two newbie questions
Post by andrew » Sat Sep 24, 2016 9:18 am
sfmac wrote:1) Is it possible to set the size of the default viewport? I work with very small models and only need a viewport 24 inches (x direction) and 12 inches (y direction. Currently would have to zoom in every time.
You might want to start all your new drawings by loading a drawing as template (with all your usual layers, a drawing border, etc.).
sfmac wrote:2) I have tried to cancel the 'trial' displays for CAM and QCAD PRO. I click the "Remove " button for both but they just return when I boot up. Is there a way to permanently turn them off?
When you click the remove link, a dialog shows you which files will be removed. Simply remove those files manually (QCAD does not appear to have sufficient permissions on your system to remove them).
