Tiny drawings
Archi
Tiny drawings
Post by Archi » Wed Sep 28, 2016 10:23 pm
Hi. We created drawings using the 'community' version of Q CAD which looked fine on screen (at a 1:50 scale with real size), but when we used print preview the drawings shrunk to a minute size & there was no visible picture. After much fiddling with the 'drawing preferences', setting the drawing and paper units both to millimetres & printing/paper scale to A4 size & viewpoint to 1:50 (zero point), we can actually see something of the drawings but they are still very small on the paper & are on 2 pieces rather than 1. Is there some way we can scale them up so they are visible & on one piece of A4 & keep a 1:50 scale to print (for planning submission)?
Re: Tiny drawings
Post by Husky » Thu Sep 29, 2016 12:35 am
Hello Archi - welcome to the forum.
Archi wrote:... Is there some way we can scale them up so they are visible & on one piece of A4 & keep a 1:50 scale to print (for planning submission)?
I'm pretty sure there is an easy way to scale them correctly ... :wink:
Could you please attach one of those drawings or at least an example drawing what shows the problem too. Thanks.
Re: Tiny drawings
Post by Clive » Thu Sep 29, 2016 9:50 am
Hi Archi
Leave the view port scale in the drawing preferences at 1:1. Draw out your floor layout 1:1 in model space, then scale when you are in print preview.
Archi
Re: Tiny drawings
Post by Archi » Mon Oct 03, 2016 9:10 pm
Husky wrote:Hello Archi - welcome to the forum.
Hi
Thanks for offer of help, much appreciated. I have attached the drawings - aiming to get all elevations on one piece of A4. Garden plan is also on the document, but this can go on a different piece of A4. I note the comment from Clive, but as the drawings are already done (I believe in 1:50) I think this is why his plan doesn't work.
Elevations.dxf
(1.11 MiB) Downloaded 270 times
Re: Tiny drawings
Post by Husky » Mon Oct 03, 2016 9:56 pm
Hello Archi - thank you for the drawing!
First of all - there is a 1:1(I believe) copy in your drawing - I decided to delete one! Is that OK? :wink:
Archi wrote:
Husky wrote:I note the comment from Clive, but as the drawings are already done (I believe in 1:50) I think this is why his plan doesn't work.
Common practice is to draw everything in 1:1 - no matter how big your drawing is. For printing you will scale it down or up in the print dialog - not earlier.
I played a little bit with your drawing and this is the first approach to print it:
or
Is that what you are looking for? If yes I will explain what I have done. Oh, before I forgot it - I need one reference dimension to check the scale. Lengths of a wall or what ever is available.
Archi
Re: Tiny drawings
Post by Archi » Mon Oct 10, 2016 9:25 pm
Many thanks for looking at this. This is looking much more like what we were trying to do - ultimately we need to put all the elevations on one page for a planning application. The reference dimension is 5 metres for the end wall on the right of the floor plan diagram (side of kitchen).
Re: Tiny drawings
Post by Husky » Tue Oct 11, 2016 7:41 pm
Ok - here is what needs to be done with the drawing ...
Load the drawing,
check Printing page size (Edit / Drawing Preferences) "Page",
Paper: reset Custom to A4, Viewport: Scale to 1:1, Offset: reset to Zero point,
OK
Drawing:
Scale drawing to 1:1 (in this case factor 100)
then (Edit / Drawing Preferences) "Dimension Settings"
Set Dimension Settings / Text height to 250
OK
Print Preview
Scale 1:50
Move Paper Position to that what needs to be printed
Auto Zoom to page
Print ;)
Archi
Re: Tiny drawings
Post by Archi » Mon Oct 24, 2016 5:44 pm
Many thanks for this. All working great now! Much appreciated.
