Offset bug with clipping on
trongdong
Post by trongdong » Fri May 12, 2017 5:46 am
Hello everyone,
First, thank you so much for give us such a brilliant software.
When using qcad, I think we found an issue with offset feature.
If we disable the clipping feature, it works just fine.
I also attach 2 images here with clipping on and off so you understand what happens!
clipping on.png (9.77 KiB) Viewed 4389 times
clipping off.png (11.16 KiB) Viewed 4389 times
Re: Offset bug with clipping on
Post by andrew » Fri May 12, 2017 8:04 am
Thanks for your report.
- indicate the operating system you are using and the version thereof
- indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD)
- attach original drawing files (DXF, DWG, ...) if appropriate
