Modify the toolbar at run-time?
pietro_72_
Location: http://creativitainformaticart.altervista.org
Post by pietro_72_ » Mon Jun 12, 2017 11:39 am
Hello
Can I change the toolbar depending on the option you choose on a QComboBox on the same toolbar?
Re: Modify the toolbar at run-time?
Post by andrew » Mon Jun 12, 2017 12:04 pm
Yes, you can use the QToolBar API to remove widgets from a toolbar or add new widgets.
