No visibility icons on block or layer list
massimo
Post by massimo » Sun Nov 19, 2017 3:23 pm
Hi, I'm running some recent nightly build from Oct 23.
On the block or layer list widgets, I can't see any icons anymore for fast switching the visibility. The only way is by using the context menu. Wasn't there some shortcut button per layer or block in the past?
git build current origin/master, Gentoo Linux on amd64
Re: No visibility icons on block or layer list
Post by Husky » Sun Nov 19, 2017 9:39 pm
massimo wrote:The only way is by using the context menu. Wasn't there some shortcut button per layer or block in the past?
Yes - and it is still the case:
Community Edition:
I recommend a new installation - use a trial package from this site
http://www.qcad.org/de/qcad-downloads-trial
Make sure to pick the right OS and bit system (32/64), don't mix a new installation with an old one (same directory). After that you can remove the Trial feature and it will work as a Community Edition.
massimo
Post by massimo » Mon Nov 20, 2017 9:49 am
Ok, but should we check why the self build version from sources doesn't have the feature? I prefer compiling from git for easy update on Gentoo.
This is a fresh source directory and started with an empty ~/.config/QCAD
$ git log -1
commit 3823f6793e9e105325f0fc4d7041f615c395fddd (HEAD -> master, origin/master, origin/HEAD)
Author: Andrew Mustun <andrew@qcad.org>
Date:   Fri Nov 17 15:36:00 2017 +0000
    update script bindings
See the screenshot.
$ ldd ~/src/other/qcad/release/qcad-bin
	linux-vdso.so.1 (0x00007fffc97bd000)
	libqcadecmaapi.so => /home/massimo/src/other/qcad/release/libqcadecmaapi.so (0x00007f6cedffc000)
	libqcadgui.so => /home/massimo/src/other/qcad/release/libqcadgui.so (0x00007f6cedd79000)
	libqcadentity.so => /home/massimo/src/other/qcad/release/libqcadentity.so (0x00007f6ceda6b000)
	libqcadoperations.so => /home/massimo/src/other/qcad/release/libqcadoperations.so (0x00007f6ced849000)
	libqcadspatialindex.so => /home/massimo/src/other/qcad/release/libqcadspatialindex.so (0x00007f6ced63d000)
	libspatialindexnavel.so => /home/massimo/src/other/qcad/release/libspatialindexnavel.so (0x00007f6ced3c8000)
	libqcadgrid.so => /home/massimo/src/other/qcad/release/libqcadgrid.so (0x00007f6ced1bd000)
	libqcadsnap.so => /home/massimo/src/other/qcad/release/libqcadsnap.so (0x00007f6cecfa8000)
	libqcadcore.so => /home/massimo/src/other/qcad/release/libqcadcore.so (0x00007f6cec82c000)
	libqcadstemmer.so => /home/massimo/src/other/qcad/release/libqcadstemmer.so (0x00007f6cec5fd000)
	libqcadzip.so => /home/massimo/src/other/qcad/release/libqcadzip.so (0x00007f6cec3fa000)
	libquazip.so => /home/massimo/src/other/qcad/release/libquazip.so (0x00007f6cec1cc000)
	libGLU.so.1 => /usr/lib64/libGLU.so.1 (0x00007f6cebf4c000)
	libQtWebKit.so.4 => /usr/lib64/qt4/libQtWebKit.so.4 (0x00007f6cea341000)
	libQtScriptTools.so.4 => /usr/lib64/qt4/libQtScriptTools.so.4 (0x00007f6cea081000)
	libQtScript.so.4 => /usr/lib64/qt4/libQtScript.so.4 (0x00007f6ce9bc2000)
	libQtSvg.so.4 => /usr/lib64/qt4/libQtSvg.so.4 (0x00007f6ce9969000)
	libQtXmlPatterns.so.4 => /usr/lib64/qt4/libQtXmlPatterns.so.4 (0x00007f6ce9303000)
	libQtOpenGL.so.4 => /usr/lib64/qt4/libQtOpenGL.so.4 (0x00007f6ce9005000)
	libQtXml.so.4 => /usr/lib64/qt4/libQtXml.so.4 (0x00007f6ce8dc0000)
	libGL.so.1 => /usr/lib64/libGL.so.1 (0x00007f6ce8b4e000)
	libQtDesigner.so.4 => /usr/lib64/qt4/libQtDesigner.so.4 (0x00007f6ce83e7000)
	libQtHelp.so.4 => /usr/lib64/qt4/libQtHelp.so.4 (0x00007f6ce8159000)
	libQtSql.so.4 => /usr/lib64/qt4/libQtSql.so.4 (0x00007f6ce7f18000)
	libQtGui.so.4 => /usr/lib64/qt4/libQtGui.so.4 (0x00007f6ce7234000)
	libQtNetwork.so.4 => /usr/lib64/qt4/libQtNetwork.so.4 (0x00007f6ce6eed000)
	libQtCore.so.4 => /usr/lib64/qt4/libQtCore.so.4 (0x00007f6ce69fe000)
	libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f6ce67de000)
	libstdc++.so.6 => /usr/lib/gcc/x86_64-pc-linux-gnu/6.4.0/libstdc++.so.6 (0x00007f6ce63de000)
	libm.so.6 => /lib64/libm.so.6 (0x00007f6ce608d000)
	libgcc_s.so.1 => /usr/lib/gcc/x86_64-pc-linux-gnu/6.4.0/libgcc_s.so.1 (0x00007f6ce5e76000)
	libc.so.6 => /lib64/libc.so.6 (0x00007f6ce5ab1000)
	libX11.so.6 => /usr/lib64/libX11.so.6 (0x00007f6ce5774000)
	libz.so.1 => /lib64/libz.so.1 (0x00007f6ce555d000)
	libsqlite3.so.0 => /usr/lib64/libsqlite3.so.0 (0x00007f6ce5244000)
	libXrender.so.1 => /usr/lib64/libXrender.so.1 (0x00007f6ce503a000)
	libicuuc.so.58 => /usr/lib64/libicuuc.so.58 (0x00007f6ce4c93000)
	libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00007f6ce49ce000)
	libdl.so.2 => /lib64/libdl.so.2 (0x00007f6ce47ca000)
	libexpat.so.1 => /usr/lib64/libexpat.so.1 (0x00007f6ce45a0000)
	libxcb-dri3.so.0 => /usr/lib64/libxcb-dri3.so.0 (0x00007f6ce439d000)
	libxcb-xfixes.so.0 => /usr/lib64/libxcb-xfixes.so.0 (0x00007f6ce4194000)
	libxcb-present.so.0 => /usr/lib64/libxcb-present.so.0 (0x00007f6ce3f91000)
	libxcb-sync.so.1 => /usr/lib64/libxcb-sync.so.1 (0x00007f6ce3d8a000)
	libxshmfence.so.1 => /usr/lib64/libxshmfence.so.1 (0x00007f6ce3b88000)
	libglapi.so.0 => /usr/lib64/libglapi.so.0 (0x00007f6ce3957000)
	libXext.so.6 => /usr/lib64/libXext.so.6 (0x00007f6ce3745000)
	libXdamage.so.1 => /usr/lib64/libXdamage.so.1 (0x00007f6ce3542000)
	libXfixes.so.3 => /usr/lib64/libXfixes.so.3 (0x00007f6ce333c000)
	libX11-xcb.so.1 => /usr/lib64/libX11-xcb.so.1 (0x00007f6ce313a000)
	libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x00007f6ce2f10000)
	libxcb-glx.so.0 => /usr/lib64/libxcb-glx.so.0 (0x00007f6ce2cf3000)
	libxcb-dri2.so.0 => /usr/lib64/libxcb-dri2.so.0 (0x00007f6ce2aee000)
	libXxf86vm.so.1 => /usr/lib64/libXxf86vm.so.1 (0x00007f6ce28e8000)
	libdrm.so.2 => /usr/lib64/libdrm.so.2 (0x00007f6ce26d6000)
	libQtCLucene.so.4 => /usr/lib64/qt4/libQtCLucene.so.4 (0x00007f6ce23d7000)
	libglib-2.0.so.0 => /usr/lib64/libglib-2.0.so.0 (0x00007f6ce20c3000)
	libpng16.so.16 => /usr/lib64/libpng16.so.16 (0x00007f6ce1e8d000)
	libgobject-2.0.so.0 => /usr/lib64/libgobject-2.0.so.0 (0x00007f6ce1c39000)
	libSM.so.6 => /usr/lib64/libSM.so.6 (0x00007f6ce1a31000)
	libICE.so.6 => /usr/lib64/libICE.so.6 (0x00007f6ce1816000)
	libXi.so.6 => /usr/lib64/libXi.so.6 (0x00007f6ce1606000)
	libXrandr.so.2 => /usr/lib64/libXrandr.so.2 (0x00007f6ce13fb000)
	libXcursor.so.1 => /usr/lib64/libXcursor.so.1 (0x00007f6ce11f0000)
	libXinerama.so.1 => /usr/lib64/libXinerama.so.1 (0x00007f6ce0fed000)
	libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1 (0x00007f6ce0da8000)
	libssl.so.1.0.0 => /usr/lib64/libssl.so.1.0.0 (0x00007f6ce0b3a000)
	libcrypto.so.1.0.0 => /usr/lib64/libcrypto.so.1.0.0 (0x00007f6ce06fd000)
	librt.so.1 => /lib64/librt.so.1 (0x00007f6ce04f5000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f6cef64e000)
	libicudata.so.58 => /usr/lib64/libicudata.so.58 (0x00007f6cde9f3000)
	libbz2.so.1 => /lib64/libbz2.so.1 (0x00007f6cde7e3000)
	libXau.so.6 => /usr/lib64/libXau.so.6 (0x00007f6cde5df000)
	libXdmcp.so.6 => /usr/lib64/libXdmcp.so.6 (0x00007f6cde3d9000)
	libpcre.so.1 => /lib64/libpcre.so.1 (0x00007f6cde167000)
	libffi.so.6 => /usr/lib64/libffi.so.6 (0x00007f6cddf5e000)
	libuuid.so.1 => /lib64/libuuid.so.1 (0x00007f6cddd57000)
	libbsd.so.0 => /usr/lib64/libbsd.so.0 (0x00007f6cddb41000)
Post by andrew » Mon Nov 20, 2017 10:08 am
Likely some incompatible Qt SVG plugin that is loaded.
Note that random git checkouts are not guaranteed to run or even compile. If you do checkout from git, please make sure you use a tagged version.
For any use of QCAD that goes beyond testing or playing around, official builds from our web site should be used. Note that we also apply various patches to Qt, so bug reports from self-built versions are usually not even considered.
massimo
Post by massimo » Wed Nov 22, 2017 5:57 pm
I have built against Qt4. So you say your builds are compiled against a custom patched Qt and that one is statically linked and packaged with your binary installation?
Then I have no chance to get that built at all that way, using an official Qt here?
Post by andrew » Wed Nov 22, 2017 6:02 pm
massimo wrote:I have built against Qt4. So you say your builds are compiled against a custom patched Qt and that one is statically linked and packaged with your binary installation?
No, Qt is dynamically linked.
massimo
Post by massimo » Wed Nov 22, 2017 6:11 pm
Ok, but I meant you provide your own Qt with the package and not dynamically linking to system provided Qt in /usr/share?
Post by andrew » Wed Nov 22, 2017 6:13 pm
That's correct.
GrinoWri
Post by GrinoWri » Sun Nov 26, 2017 9:50 pm
Massimo,
following up with our discussion at https://bugs.gentoo.org/498656 - I have successfully compiled QCAD 3.19.1.0 against QT 5.9.2 using the ebuild attached in the Gentoo bug tracker and I do not get your icon issue:
Screenshot of QCAD 3.19.1.0 linked against QT 5.9.2
Screen Shot 2017-11-27 at 12.35.23 AM.png (295.61 KiB) Viewed 4694 times
Please try QT 5.9.2 with QCAD 3.19.1.0.
