QCAD release Run the error
Wqwlq
Post by Wqwlq » Fri Dec 01, 2017 2:36 am
Run the error, prompt "ReferenceError: Can not find Variable: QPlainTextEdit", QPlainTextEdit does not know where to add?
Re: QCAD release Run the error
Post by andrew » Fri Dec 01, 2017 10:12 am
Please be much more specific. What package are you running? Did you download it from our web site or did you compile the code? What platform are you on? What version of Qt are you using? Thanks.
