Hatching
LouiseSJPP
Hatching
Post by LouiseSJPP » Thu Jan 11, 2018 5:10 pm
How should I best go about hatching a drawing like the attached? I've tried Hatch From Selection but the selection process seems to drop out long before I've got all around the stairs.
Louise
Win 10 QCAD Version: 3.19.2.0 (3.19.2) Internet: QCAD.org Build Date: Dec 20 2017 Revision: 1f70332Qt Version: 5.5.1 Architecture: x86_64 Compiler:MSVC++ 12.0 (2013)
Re: Hatching
Post by Clive » Thu Jan 11, 2018 7:20 pm
Hi Louise,
Nice drafting work.
Try the 'Hatch from segments' tool instead!
Regards
LouiseSJPP
Re: Hatching
Post by LouiseSJPP » Thu Jan 11, 2018 8:07 pm
Clive wrote:Hi Louise,
Nice drafting work.
Regards
But how does the tool work?
Louise
Re: Hatching
Post by Clive » Fri Jan 12, 2018 9:23 am
Essentially you would use this tool to select entities to form a boundary to hatch within, the boundary needs to be closed without any gaps at all.
