Share my state between different scripts
sarlaa
Post by sarlaa » Fri Mar 16, 2018 12:46 pm
Could you tell me how can I share my state, that contains data related to document with format json, with all scripts as data global ?
I saw this reference viewtopic.php?f=30&t=3187&p=11338&hilit ... ble#p11338
but it seems that works just for primitifs type variables.
Regards.
Re: Share my state between different scripts
Post by andrew » Fri Mar 16, 2018 2:04 pm
The approach for application wide, non-persistent data should work fine also for JSON:
var appWin = RMainWindowQt.getMainWindow();
appWin.setProperty("MyProperty", {"a":3, "b":7, ...});
var value = appWin.property("MyProperty")["a"];
