Loading SKP files
bvd4
Loading SKP files
Post by bvd4 » Fri Mar 23, 2018 9:42 am
Is it possible to load skp files into qcad
Re: Loading SKP files
Post by andrew » Fri Mar 23, 2018 9:47 am
Not directly. You'd have to either save your file as DXF/DWG or find a file format converter.
bvd4
Post by bvd4 » Fri Mar 23, 2018 9:53 am
thanks I will and get the files converted
Return to “Chat”
