Qcad Manual.
TreestumpExhaustpipe
Qcad Manual.
Post by TreestumpExhaustpipe » Tue Jun 12, 2018 5:54 pm
QCAD manual from the interface is not searchable and google searches only brings up one grainy video I cant make out.
Is there e.g. a searchable pdf version of the manual available?
The html version from the interface in qcad is pretty useless as it has no search function.
Re: Qcad Manual.
Post by andrew » Tue Jun 12, 2018 6:00 pm
You can use the "Search" tab on the left to search the integrated user manual (Help > Reference Manual):
Screen Shot 2018-06-12 at 17.58.42.png (192.49 KiB) Viewed 1079 times
Re: Qcad Manual.
Post by TreestumpExhaustpipe » Tue Jun 12, 2018 7:01 pm
Attached see Proof that there is NO search field in the manual.
A PDF would be a good plaster for the bug.
Do you have a PDF version?
Re: Qcad Manual.
Post by andrew » Tue Jun 12, 2018 7:34 pm
You're using the trial version or free QCAD Community Edition. The integrated / searchable manual is part of QCAD Professional.
