How Do I change the Label Direction / Text Direction of Dimension Tools
schrodinger
Post by schrodinger » Thu Jul 26, 2018 11:40 am
By default, the label direction /text direction of dimension tool is horizontal.
How do I change the direction, so it is vertical (or more general, any other angle desired), like this:
Thanks!
TSG
Re: How Do I change the Label Direction / Text Direction of Dimension Tools
Post by TSG » Thu Jul 26, 2018 12:03 pm
There is no easy way to change the text direction of a dimension.
The only way I know is to explode (xp) the dimension and then manipulate the text separately.
But attention: you loose the relation between dimension and text. That means changing the dimension will not change the text anymore.
regards Thomas
schrodinger
Post by schrodinger » Fri Jul 27, 2018 2:06 am
Thanks, Tohmas. Your suggestion is a feasible workaround. Hope this can be included in furture updates.
Post by Husky » Fri Jul 27, 2018 4:57 am
Your best chance to get something like that in a future QCAD Version would be to file a "Feature Request". The developer will then decide to implement it or not. :wink:
http://www.ribbonsoft.com/bugtracker
Don't be confused by the link - that forum is used for bug reports and feature requests.
