Browse Tool?
turtle
Browse Tool?
Post by turtle » Thu Dec 13, 2018 7:56 pm
Greetings all, often when I reopen a drawing that I have not used in a long time or from another program it is super zoomed out and hard to find the actual drawing to zoom into.
Is there a hand 'browse' tool that will push the drawing around for me?
Thanks in advance.
Re: Browse Tool?
Post by andrew » Thu Dec 13, 2018 9:38 pm
Auto zoom should usually do the trick:
View > Zoom > Auto Zoom
If not, there are entities (probably unwanted entities) causing the auto zoom to be off. To get more detailed help, please attach your drawing file.
Re: Browse Tool?
Post by Husky » Thu Dec 13, 2018 9:42 pm
you can adjust the Load settings below Graphics View / Appearance
That will cover ALL entities on load but nothing more. The rest can be done easily with the zoom tools.
turtle
Re: Browse Tool?
Post by turtle » Thu Dec 13, 2018 10:14 pm
Thanks All!
