Print Preview Pan not working
LouiseSJPP
Post by LouiseSJPP » Fri Feb 01, 2019 6:07 pm
I've recently re-installed Windows 10 and afterwards found that Print Preview Pan didn't work. I restarted QCAD and it did work, but has bow stopped working again. Restarting doesn't fix it.
Windows 10
Version 3.21.3.0 (3.21.3)
DXF attached
Errecaldia dining room 02.dxf
(286.04 KiB) Downloaded 40 times
Re: Print Preview Pan not working
Post by Husky » Fri Feb 01, 2019 6:42 pm
Works for me. However - can you test the modified drawing and tell us if the issue persist or not.
Errecaldia dining room 02_mod.dxf
(288.21 KiB) Downloaded 40 times
LouiseSJPP
Post by LouiseSJPP » Sun Feb 03, 2019 2:35 pm
Both versions now pan!! But thank you...
LouiseSJPP
Post by LouiseSJPP » Thu Feb 07, 2019 3:56 pm
Still occasionally refuses to pan....
