QCAD fails to launch
KBBB
Post by KBBB » Sat Feb 09, 2019 5:01 pm
Can you help with QCAD not launching? It will load to 69% and fails at loading CAM ADD SUBLAYER.
Re: QCAD fails to launch
Post by andrew » Mon Feb 11, 2019 10:00 am
Please wipe your installation making sure the QCAD installation directory is completely removed, then install from scratch. If that does not help, you might also want to reset your QCAD configuration.
