Layer States
Eelie
Layer States
Post by Eelie » Tue Apr 16, 2019 4:16 pm
The QCAD online tutorial shows how Layer States can be created and saved and that this tool is turned on from the Layers menu. The Layer States feature does not appear in the Layers menu in my recently loaded, and apparently up to date, version of QCAD Professional. Is this feature available or not?
Re: Layer States
Post by andrew » Tue Apr 16, 2019 4:53 pm
This feature is planned for the next release of QCAD.
You can already preview and use this feature in the current snapshot release (considered "unstable", not for production use) if you are interested. Snapshots are available from your download link under "Snapshots".
Eelie
Re: Layer States
Post by Eelie » Wed Apr 17, 2019 11:08 am
That's great, I'll wait for the new release. Thank you
TSG
Re: Layer States
Post by TSG » Fri Apr 19, 2019 8:00 am
I'm using QCAD Pro 3.22.0.7 with macos.
The new function "layer status" works pretty well but after saving and reloading the drawing the shortcuts y1, y2 ... are not available.
Please fix it.
Thomas
Re: Layer States
Post by andrew » Fri Apr 19, 2019 8:12 am
I cannot reproduce.
Can you please outline the steps?
E.g.
- File > Load, File > Close, File > Load
or
- File > Load, File > Reload, etc.
TSG
Re: Layer States
Post by TSG » Fri Apr 19, 2019 10:40 am
I got it.
On my imac the tool palettes are on a second monitor!!!
After reloading the drawing my cursor was not in the main window but in the layer or block list on the second monitor.
Then pressing y1, y2, ... had no effect.
I had to move the cursor into the main window or into other lists including property editor and library browser which are also on the second monitor!!! Then y1, y2, ... is working as expected.
Can you fix it, so that wherever the cursor is positioned on a second monitor y1, y2, ... will work?
Thomas
Re: Layer States
Post by Husky » Fri Apr 19, 2019 7:04 pm
I can reproduce it ..... kind of.
Working on Win10 / second Monitor but which is used as primary monitor. First one is off.
I have never seen y2 or y3?
I can use VM from the menu, used in the command line will tell me unknown command. Same with y1, y2 ...
Looking in "Application Preferences" for what y2 etc stands for brings no results.
Re: Layer States
Post by Husky » Sat Apr 20, 2019 4:59 am
Oups - If I use vm in the command line I got the alert that this is a "Unknown command or invalid coordinate or value: "vm"" and then it will stay there regardless which tool is used after that. Only a QCAD reboot will fix the issue.
Here I'm using the tool circle. center, point:
