Set min. line thickness when using dwg2pdf
sistemas.caw
Post by sistemas.caw » Mon Apr 22, 2019 4:08 pm
Have any way to set min. line thickness when using dwg2pdf script?
Att,
Rhodolfo Novochadlo.
Re: Set min. line thickness when using dwg2pdf
Post by andrew » Tue Apr 23, 2019 9:40 am
Yes, from dwg2pdf -h:
-w, -min-lineweight=LW  Set minimum line weight to LW drawing units
sistemas.caw
Post by sistemas.caw » Tue Apr 23, 2019 3:22 pm
Andrew,
Thank you very much for your quickly reply,
I tried to use -w parameter. But, for some files this parameter have different behaviours. Look attached files.
PDF1 was generated using CAD1 with command (dwg2pdf.bat -a -c -d -f -n -l -w 0.5 -fs romans standard -fs romand standard -o "C:\Temp\a\2pdf\PDF1.pdf" "C:\Temp\a\2pdf\CAD1.DWG")
PDF2 was generated using CAD2 with command (dwg2pdf.bat -a -c -d -f -n -l -w 0.5 -fs romans standard -fs romand standard -o "C:\Temp\a\2pdf\PDF2.pdf" "C:\Temp\a\2pdf\CAD2.DXF")
I think that -a parameter is conflicting with -w
CAD2.pdf
(31.08 KiB) Downloaded 95 times
CAD2.DXF
(73.02 KiB) Downloaded 128 times
CAD1.pdf
(64.08 KiB) Downloaded 103 times
CAD1.dwg
(24.81 KiB) Downloaded 112 times
Post by andrew » Wed Apr 24, 2019 9:47 am
Yes, the value is in drawing units, not paper units. 0.5mm in drawing units are wider when zoomed in.
This might change in a future version to define a minimum lineweight independent of the zoom level.
sistemas.caw
Post by sistemas.caw » Thu Apr 25, 2019 5:12 pm
Andrew, thank you very much for your help.
Do you know when is the prevision of QCad release with this improvement? This is very critical for my application and if take a long time I will need to study other solution for me.
regards,
Rhodolfo Novochadlo
Post by andrew » Thu Apr 25, 2019 6:56 pm
It will be in the next snapshot release, usually released within a few days.
Snapshot releases are announced at:
https://www.qcad.org/rsforum/viewforum.php?f=16
sistemas.caw
Post by sistemas.caw » Thu Apr 25, 2019 9:05 pm
Thank you very much Andrew, I will wait.
garciadelcastillo
Post by garciadelcastillo » Thu May 23, 2019 10:49 pm
Same problem here with "dwg2bmp", did this feature make it to 3.22.1?
Post by andrew » Fri May 24, 2019 8:46 am
Yes.
