G71 Gcode
mthomas
G71 Gcode
Post by mthomas » Tue May 21, 2019 1:50 pm
Using qcad set for GRBL (mm) almost always generates a G71 G91.1 line in the exported gcode header. The G91.1 is fine but G71 just stops the controller, always need to manually edit the generated file and remove it. Any ideas as to why this is happening, G71 in the case of standard mil/drill operations doesn't make sense.
Re: G71 Gcode
Post by andrew » Tue May 21, 2019 1:59 pm
G71 sets the unit of the controller to Millimeter.
You can simply create your own post processor in the "postprocessors" directory as follows:
File name: "MyGrblMM.js"
File contents:
include("Grbl.js");
function MyGrblMM(documentInterface, camDocumentInterface) {
    Grbl.call(this, documentInterface, camDocumentInterface);
    this.decimals = 4;
    this.unit = RS.Millimeter;
    this.outputOffsetPath = true;
    this.header = [
        "[N] G21 G17 G90 G40 G49 G80",
        "[N] G91.1"
MyGrblMM.prototype = new Grbl();
MyGrblMM.displayName = "My Grbl (offset) [mm]";
The choos the post processor "My Grbl (offset) [mm]".
mthomas
Re: G71 Gcode
Post by mthomas » Tue May 21, 2019 2:05 pm
Thanks for the quick response. I would have thought G21 would set up metric but good to know the header can be altered.
