Contour Elevation Data
bronic
Post by bronic » Thu Sep 05, 2019 5:27 am
I tried searching the forum but couldn't find the answer I need, forgive me if I missed something.
I'm curious if contour elevation data is retained when opening a .dwg file in qcad. While testing the trial version when I selected a contour I was only given an X and Y dimension in the properties toolbox.
I realize this isn't 3d CAD software, and I don't need to visualize anything in 3d. But I just need to know if I open a .dwg with contour lines containing elevation data, if that elevation info is accessible anywhere in qcad.
Thanks,
Nick
Re: Contour Elevation Data
Post by Husky » Thu Sep 05, 2019 7:08 am
QCAD is a straight 2D CAD program and has very limited abilities to show z dimension. But for those cases you can activate the Z coordinates within the Property Editor.
You could also use Custom Properties to provide elevation data:
That's depends on the drawing. There are different ways to give a drawing the info for the elevation. If it is a plain 2D drawing then I'm pretty sure the drafter used a 2D readable method. Is it a 3D drawing then many 3D CAD programs are able to export it as 2D or you even could use a converter to convert it a 2D what makes it usable in QCAD.
Whatsoever - If you try to open a 3D drawing with QCAD then it will properly fail.
To take out the guesswork do you have an example drawing to see what you try to accomplish?
bronic
Post by bronic » Thu Sep 05, 2019 7:30 am
Husky,
Thanks very much for your reply. That's helpful. Here is an example of a drawing I'd like to be able to reference the elevation of the contour.
FYI, I know this file will display an elev in autocad
ACAD-C-TOPO-Model 11.1.18.dwg
(5.64 MiB) Downloaded 86 times
Post by Husky » Thu Sep 05, 2019 8:33 am
Thanks for the exsample drawing.
Here the bad news: That is a plain 3D drawing and not meant to be proceed in QCAD. Surprisingly I can open it in QCAD but that is more luck than anything else ...
The good news is that I can read the stored values for elevation ....
... and see the 3D elevations ...
... but that is not a proper way to process a 3D drawing.
Long story short: If you have only access to 3D drawings then is QCAD not the right option to process them.
bronic
Post by bronic » Thu Sep 05, 2019 8:38 am
Husky,
That answers my question.
Thanks so much for your help, it is appreciated!
Post by Husky » Thu Sep 05, 2019 9:09 am
You're welcome. :wink:
Post by CVH » Thu Sep 05, 2019 12:55 pm
Can you explain how this is done?
Post by Husky » Thu Sep 05, 2019 7:12 pm
That was done with a non QCAD related program.
Post by CVH » Thu Sep 05, 2019 8:02 pm
Thanks a lot,
that explain things.
