Dim accumulated an axis
Locked
ggsalas
Post by ggsalas » Sat Jan 17, 2009 3:12 pm
How do the dim of rethinking plane? = Dim accumulated an axis
Image example of the dim that I need:
Post by andrew » Sat Jan 17, 2009 5:16 pm
Ordinate dimensions might be what you are looking for.
ggsalas
Post by ggsalas » Sun Jan 18, 2009 2:14 am
andrew wrote:Ordinate dimensions might be what you are looking for.
Ordinate dimensions measuring from 0.0, I need from a variable. Besides the ordinate dimensions have no arrow.
Is simpler, it's a dim that only has an arrow and the text is aligned to one side.
Thank you.
Post by andrew » Sun Jan 18, 2009 10:16 am
ggsalas wrote:Ordinate dimensions measuring from 0.0
You can move the reference point of ordinate dimensions:
- select ordinate dimension(s)
- move blue reference point at absolute position (0,0) to desired relative zero point
Dimension entities that look exactly as shown in your figure are not supported by QCAD.
apjjr
Post by apjjr » Mon Jan 19, 2009 1:09 am
Is there a way to set the ordinate 0,0 to a relative location before drawing dimensions so we don't have to move it after drawing the dimensions?
-Alex
ggsalas
Post by ggsalas » Mon Jan 26, 2009 7:44 pm
I need not be identical to the image, but the levels I tried were really bad. Is there a way to customize your appearance?
Thank you
Post by andrew » Tue Jan 27, 2009 10:44 am
ggsalas wrote: Is there a way to customize your appearance?
No, sorry.
ggsalas
One possible solution
Post by ggsalas » Mon Feb 09, 2009 4:55 pm
I want to know whether it is possible to place a text that shows the value of the coordinate (in x).
If this is possible, Drawing a block to the levels accumulated in x and one for the levels accumulated in y
http://picasaweb.google.com/lh/photo/gT ... bedwebsite
Maybe you can use scripts?
ggsalas
Re: Dim accumulated an axis
Post by ggsalas » Wed Jul 25, 2012 5:56 pm
With blocks and/or scripts this can be possible?
Post by andrew » Wed Jul 25, 2012 6:10 pm
With a QCAD 3 script, this is certainly possible.
Have a look at the example script in scripts/Examples/DrawExamples/ExThreePoints
This script lets the user click a position and then adds three points beside each other at the chosen position.
Instead of adding points, you can add any other entity type, including text labels.
Locked
