Circle becomes Polyline - when does it happen?
Krischu
Senior Member
Post by Krischu » Tue Oct 22, 2019 8:41 am
I recall and I'm sure that I created all holes in my drawing as being circles. Now I notice that they have become Polylines (which makes it difficult to locate their centre points).
I suspect that it is not possible to revert that back, isn't it?
Could it be that the action "Segments to Poly" (OG) did that?
Christoph
Panchdara
Senior Member
Re: Circle becomes Polyline - when does it happen?
Post by Panchdara » Tue Oct 22, 2019 10:01 am
Hi. I guess you can't convert a poly back to a circle, but to find the center point, you could use Menu/Misc/Draw/Centerline (as described in a post recently). OR, you could select the circular poly and draw another circle (on a separate layer) based on 2 opposite points, then delete the original and change the new circle layer to the original layer???
QCAD 3.25.2.x / Windows 10 2004 x86_64
Post by CVH » Tue Oct 22, 2019 11:52 am
There are two Qcad candidates that do that with a Circle:
The function Explode >> Geo Closed Poly 3 vertex 2 nodes bulging 180°
The function Poly from Selection >> Logically Closed Poly 2 vertex 2 nodes bulging 180°
(Look up: bulging can't be 360°)
And a third would be EAGLE: All entities in your recent file were Polys.
There is no way back.
Not that I know of.
Besides when the Undo in Qcad is within scope.
You could explode the 'round' Poly to two arc's with the same centerpoint as the original circle.
Krischu
Senior Member
Post by Krischu » Tue Oct 22, 2019 2:40 pm
Sorry, I messed up that circle issue, and excuses for wasting your time. I was indeed starting from an import of EAGLE geometry instead working further on my initial QCAD-construction.
Christoph
