Crankshaft Position Wheel
sandyg
Post by sandyg » Tue Dec 24, 2019 1:25 am
This is my first attempt at a plug in, feedback please!
This evolved from the spur gear library plug in. It is for use in creating an engine position wheel which is used by fuel injection and ignition systems in cars. This is specifically for my race car that needed a specialized size, which would have been easy to manually do in QCAD. However I saw the gear plug in and figured I would give it a go and see how far I can get.
Ultimately these would be cut out of steel with the waterjet or laser process.
V1.0 has a bunch of features, need to add a few more as indicated in the Readme.
This is my GitHub with the code and information - https://github.com/sganz/CrankWheel
Lot's to learn, any feedback would be fantastic.
Example wheel
Sandy
Re: Crankshaft Position Wheel
Post by Husky » Tue Dec 24, 2019 7:51 am
Interesting idea. :wink:
I started testing it but with my GUI arrangement I miss a scrollbar for an easy and complete dialog access. Is a vertical dialog scrollbar planed for future updates?
sandyg
Post by sandyg » Tue Dec 24, 2019 6:26 pm
I'll will have to see how the scroll works. I would guess it's under QCAD control directly but will look into that. You may just have to tear out the dialog or stretch it bigger. I shrunk up my other dialogs while testing.
In process to also make the bottom teeth roots a cup shape. Will require another GUI field so need to solve scroll fields into view...
Thanks for testing. Hopefully I can play a bit today and find a solution for scroll of the form.
Sandy
sandyg
Post by sandyg » Tue Dec 24, 2019 9:35 pm
Added a scrolling area to the parameter dialog. Seems to work. Doing some minor testing and clean up will have a bit more work on it before I merge to master hopefully today.
Thanks for the idea on the scrolling area.
Sandy
sandyg
Post by sandyg » Mon Dec 30, 2019 4:54 pm
Fixed up a lot of code and the display in the current Github master branch. Seems much better now to possibly call it a v1.0
sandyg
Post by sandyg » Mon Jan 06, 2020 5:02 pm
Updated code in GitHub to a v1.0.1 Readme updated with new features such as a balance hole.
Created the Crank Wheel that I needed for my application and sent it to the laser cutter. Should have it about 10 days.
Here's what I did (made 2 with some spacers).
sandyg
Post by sandyg » Sat Jan 11, 2020 5:27 pm
Got metal last night from the laser cutter. Came out very nice. Was made out of .25" hot rolled and pickled steel.
Post by andrew » Sat Jan 11, 2020 7:18 pm
Cool stuff! It's always great to see some real-life work people do with QCAD :D Thanks!
sandyg
Post by sandyg » Wed Jan 15, 2020 12:51 am
It's my go to 2D CAD package, I have been using it for years. I never get enough time to get great at it but it always works well for the Waterjet and Laser cutters. The scripting is a double bonus!
Thanks for all your hard work on it!
Sandy
