Or how do I draw a line a specific length without depending on grid snaps?
Draw a line a specific length
Re: Draw a line a specific length
Launch a line tool and use the option box to fill in the specific length of the line.
you could also use the 'Line from 2 Points', snap to geometry point for the start, move the cross hairs to hover over a known snap point, press the spacebar to make tha command line active, type in the length required and press Return.
Pete Vickerstaff
Linux Mint 20.1 Cinnamon, Qcad Pro 3.25.2.9
