Help with making a script file
Post by John Hyslop » Wed Feb 03, 2021 1:56 am
Hi All
Years ago I used to make very basic lisp files to do very very basic tasks, can anyone help me with this :|
Attached is the lisp routine :- and before anyone says yes there is probably a better way to make the lsp file
and also return osnaps to previous settings :lol:
All i want to do is select and Arc or even better window select arcs and turn them into circles.
There is a problem when sometimes exploding blocks circles become 1 arc with a start point 0
and end point 360, Qcad displays these arcs and one can assume they are circles, but when loading
the dxf into CNC software it displays as a Dot, likewise in AutoCad a dot / zero length arc e_surprised
Thanks for any help in advance
PS I didn't know how to insert it as code :cry: it kept saying Spam Detected , here is a screenshot
if you don't want to download the zip file..
A2C.LSP.zip
(427 Bytes) Downloaded 451 times
Re: Help with making a script file
Post by CVH » Wed Feb 03, 2021 5:41 am
Hi John,
Already a while QCAD doesn't explode circles to 1 full Arc but in two 2 semi full Arcs.
A Polyline that is.
Recently, explosion of circles is made optional in App.Prefs.
Below you'll find a script for full Arcs to Circles:
Regards.
// Full Arcs to Circles script by CVH
var doc = getDocument();
var di = getDocumentInterface();
var arcsCollected = [];
// Retrieve the selection:
var ids = doc.querySelectedEntities();
// Terminate without selection:
if (ids.length === 0) {
    EAction.handleUserWarning("Nothing Selected! Script terminated.");
    return;
// Filter full Arcs from selection:
for (var i=0; i<ids.length; i++) {
    // Get entity from the document:
    var entity = doc.queryEntity(ids[i]);
    // Collect when exist and is full Arc:
    if (!isNull(entity)){
        if (isArcEntity(entity)) {
            var arcSweep = Math.abs(entity.getSweep());
            if (RMath.fuzzyAngleCompare(arcSweep, Math.PI*2.0)) {
                arcsCollected.push(ids[i]);
// Terminate without full Arcs in selection:
if (arcsCollected.length === 0) {
    EAction.handleUserWarning("No full Arc entities selected! Script terminated.");
    return;
// Setup an operation:
var operation = new RModifyObjectsOperation();
operation.setText("Full Arcs to circles");
// Process collected Arcs
for (var i=0; i<arcsCollected.length; i++) {    //Cycle collected Arcs
    // Get full Arc from the document:
    var fullArc = doc.queryEntity(arcsCollected[i]);
    // Create a new Circle entity:
    var newCircle = new RCircleEntity(
                    doc,
                    new RCircleData(
                        fullArc.getCenter(),
                        fullArc.getRadius()
    // Add the new Circle to the operation:
    operation.addObject(newCircle, false, true);    // NOTuseCurrentAttributes, DOforceNew
    // Mark the full Arc to delete:
    operation.deleteObject(fullArc);
} // Loop Arcs
// Apply all modifications:
di.applyOperation(operation);
// Finished:
var msg = "Created " + arcsCollected.length + " Circle entity/ies."
EAction.handleUserInfo(msg);
EAction.handleUserMessage("Script ended.");
return;
Post by John Hyslop » Wed Feb 03, 2021 7:45 am
Thanks CVH :)
I'll try later, Yes i just tested explodes to 2 arcs that's fine for cnc, I must of seen this in a previous version of Qcad...
Re: [ Solved ] Help with making a script file
Post by John Hyslop » Wed Feb 03, 2021 8:21 am
Hi CVH
As you know I don't know much about Java scripting :cry:
I copied your text and saved it in a file a2c.js
made a folder under Scripts/Misc/c2a
and placed it there but Qcad won't run unless I remove it :oops:
Could you explain how and where i put this file so I can use it in the Qcad UI ? is it a Java script file?
I don't know e_confused
Post by CVH » Wed Feb 03, 2021 9:16 am
Sure,
It is not a GUI action ...
... with a button.
(If you want that ... :wink: )
Make selection.
Open Script Shell (GE)
Copy all.
Paste.
Saved as a *.js file
Make selection.
Run Script (XC) ...
PS: :P Herrinbore seed for BHT ready :wink:
Post by John Hyslop » Wed Feb 03, 2021 9:33 am
e_surprised Herringbone.. I bet I won't understand the equation and not be able to add :cry:
Looking forward to the maths, I bet it's a beauty..
