I have an issue with this file where the number values along both my X and Y rulers appear and disappear as I pan left-to-right or zoom in and out. I can't seem to recreate this with a different file. Any ideas?
QCAD 3.26.1
Win10 Pro
Disappearing ruler numbers
- ryancousins
- CCA Seating.dxf
- (725.35 KiB) Downloaded 607 times
- text.gif (6.27 MiB) Viewed 6709 times
Re: Disappearing ruler numbers
Confirmed with your file on Win7 32bit QCAD PRO 3.26 win installer
Thanks. Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2203
- ryancousins
Thanks Andrew.
I should mention that the "seating" block came from a really old file that was originally created with LibreCAD. I can't imagine a discrepancy in the way LibreCAD may have written that DXF would cause this issue but I thought I'd mention it.
ryancousins,
One can follow the bug fix and see that it is just some math
It is nothing in the file but the used unit and grid ...ryancousins wrote: ↑Thu Mar 11, 2021 2:55 pmI can't imagine a discrepancy in the way LibreCAD may have written that DXF would cause this issue but I thought I'd mention it.
