Interpolate circle with polyline
Post by andrew » Wed Dec 08, 2021 10:49 pm
From a QCAD user:
How can I split a circle up into line segments / interpolate a circle using line or arc segments?
Re: Interpolate circle with polyline
Post by andrew » Wed Dec 08, 2021 10:58 pm
1. Select the circle(s)
2. Modify > Split Entities
3. Enter the number of segments in the options toolbar and click the checkmark to apply
-> Your drawing now contains many small arc segments instead of the original circles
4. Draw > Polyline > Polyline from Segments
5. Click the segments shaping circles created in step 3 to convert them to polylines
-> Your drawing now contains polylines with small arc segments instead of the original circles
To convert these polylines with arc segments into polylines with line segments, you can use:
6. Draw > Polyline > Arc to Line Segments
-> Your drawing now contains polylines with small line segments instead of the original circles
TSG
From polylines to circles
Post by TSG » Thu Dec 09, 2021 6:19 pm
It would be great if it works the other way around as well. So that circles, semicircles or ellipses are automatically created from polylines. This could save a lot of work, especially when working on third-party drawings. Is there a chance of realization?
