Internet: QCAD.org
Build Date: Nov 30 2021
Revision: 62c65de
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
Xubuntu Linux 18.04 LTS
When I try to draw an entity and click the mouse over a non-snappable point, I often get this error:
If I click on a snapped point, it works, but when not over one I can't see the entity being drawn (line, dim, etc.) nor the coordinates I have enabled at the mouse pointer. When it moves over a snap point it shows up, when it moves off it disappears. If I turn snap off, the issue disappears but of course so does snap.
I noticed it a couple of times last week with other drawings, but restarting QCAD seemed to fix it. This time I even rebooted and it's still doing it. I've attached a very simple file where I was seeing this problem. The only updates to my system have been a couple of non-related applications (no system libs, etc.).
I haven't upgraded to 3.27.1 due to a bug pointed out elsewhere on the forum, although the actual issue escapes me at the moment. If someone else can reproduce the issue I'll be glad to file a bug report. If not, it must be my installation.
Thanks and Happy New Year to everyone.
