I fail to get the printed output in black and white despite of trying the different settings on the printer...and the choice "pdf" dont occur either--what can I do to solve this?
Akki
Print drawing in black and white/pdf?
Akki
Re: Print drawing in black and white/pdf?
Akki,
Please post such future questions in an appropriate forum like 'QCAD 'How Do I' Questions' or 'QCAD Troubleshooting and Problems'
Also read the forum rules at the top.
With a drawing file or just a small snippet we could help you more to the point.
Some questions:
- Printing from the Print Preview (Ctrl+Shift+P) or from Paper Space?
- Or Print (Ctrl+P) or Print Current View (Ctrl+Alt+P)?
- Have you set the option Black/White mode?
- Did you use exporting to pdf (XD) or the pdf button in the print preview?
One can also print to a logical pdf printer e.g. PDFCreator but the export method is by far more accurate.
Some questions:
Akki
I am able now to create a PDF and print it if I enable B/W mode after selecting CTRL-Shift-P.
However not getting any drawing in B/W or greyscale if i use CTRL-P and a direct print. It looks OK in the Preview (enclosed) but for the moment the only way around is to first create the pdf.
Akki
Akki
- Våningsplan ÖV.pdf
- (24.56 KiB) Downloaded 322 times
- Skärmklipp.JPG (184 KiB) Viewed 3481 times
Akki,
in the screen grab:
At the red cross one can see a minute white rectangle what represents your paper.
What is gray is outside the paper.
You might want to adapt the print scale.
https://www.ribbonsoft.com/en/tutorial-printing
in the screen grab:
