Mac OS 10.6 Snow Leopard
rapete
Post by rapete » Tue Sep 29, 2009 12:18 am
Does Qcad support Mac OS 10.6 Snow Leopard?
Post by andrew » Tue Sep 29, 2009 5:13 pm
We have reports of users running QCAD successfully on Snow Leopard and reports of users without success.
Please try the demo version of QCAD to make sure QCAD works on your system:
http://www.ribbonsoft.com/qcad_downloads.html
Official support for Snow Leopard will be added in 2-3 weeks.
FlyBoy
QCad and Snow Leopard
Post by FlyBoy » Thu Oct 29, 2009 4:47 pm
I am currently running QCad Version 2.1.3.2 under Snow Leopard. It seems to be running fine so far.javascript:emoticon(':)')
DougDB
Snow Leopard and QCad 2.2.2
Post by DougDB » Mon Dec 21, 2009 12:10 am
andrew wrote:We have reports of users running QCAD successfully on Snow Leopard and reports of users without success.
Was support for SL in the 2.2.2 up date? I'm ready to switch from Leopard to SL (it just arrived) and have work in progress, but on hold, using QCAD Pro v 2.2.2
Post by andrew » Mon Dec 21, 2009 6:30 pm
As of now, we still don't have a Snow Leopard machine here for testing. We were planning to buy one of the new iMacs but it had so many technical problems with the screens, HDs, etc, that we decided to cancel that.
Unfortunately, since Apple does not allow virtualization, we need one machine per Mac OS X version. I hope we will have a new machine by March 2010 for this purpose. Until then, you would have to try QCAD 2.2.2.0 on Snow Leopard to see if it works for you.
DougDB
Post by DougDB » Mon Dec 21, 2009 8:01 pm
Andrew:
Thank you for the quick response.
Anyone else tried SL and QCAD 2.2.2 since this string started?
Doug
peter76
Post by peter76 » Thu Jan 28, 2010 11:21 pm
Qcad 2.2.2 is working fine for me under SL :-)
Post by andrew » Fri Jan 29, 2010 8:20 pm
QCAD is meanwhile supported also under Mac OS X Snow Leopard.
ttrw
Post by ttrw » Wed Feb 24, 2010 12:14 pm
Works great for me! :)
(10.6.2)
Macbook Pro 2.14gHz 10.5.5 (UNIX!)
toddg
neither space nor alt-m activate the command window
Post by toddg » Thu Sep 09, 2010 7:26 am
I'm a keyboard user. I'd like to purchase the latest version of qcad for the mac, but i'm finding that the demo version does not place focus in the command window properly.
REPRO:
1. open a drawing
2. <space> // nothing happens
3. <alt-m> // nothing happens
4. za // zoom out to all works
5. zp // zoom pan works
So...any ideas? I'm testing against the latest demo version:
ftp://anonymous:[email protected] ... sal.tar.gz
Here's my system info:
System Software Overview:
System Version: Mac OS X 10.6.4 (10F569)
Kernel Version: Darwin 10.4.0
Boot Mode: Normal
Secure Virtual Memory: Enabled
64-bit Kernel and Extensions: No
Hardware Overview:
Model Name: MacBook
Model Identifier: MacBook4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.1 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 800 MHz
Boot ROM Version: MB41.00C1.B00
SMC Version (system): 1.31f0
Sudden Motion Sensor:
State: Enabled
Post by andrew » Thu Sep 09, 2010 8:21 am
toddg: Setting the focus on the command line has been mapped to Command-M on Mac OS X, since space is not a valid shortcut under OS X.
toddg
works like a charm
Post by toddg » Thu Sep 09, 2010 3:41 pm
Even though this is in the docs, I somehow did not understand:
35.1. Command Line
Space / Command-M
I mis-interpreted Command-M as Alt-M in my brain. Oops.
