[SOLVED] How do I hide the marker (tiny circle and crosshair) that remains after moving the last object?
Bilal_AU
Post by Bilal_AU » Fri Oct 21, 2022 5:59 am
Is there a setting to turn off the marker (circle with cross hairs) that appears after moving an object?
I am using QCAD Professional version 3.27.8 on a mac.
qcad marker.jpg (80.54 KiB) Viewed 5828 times
Re: How do I hide the marker (tiny circle and crosshair) that remains after moving the last object?
Post by Husky » Fri Oct 21, 2022 6:20 am
No. That is the Relative Zero marker used for relative positioning. What you could do is to lock that marker in a position (like Absolute Zero) with Menu/Snap/Lock Relative Zero or change the marker color to something what bother you less below Application Preferences/Graphic View/Colors. Adjusting the Alpha Chanel of a color could help too. 255 = Full visibly / 0 = invisible.
Bilal_AU
Post by Bilal_AU » Fri Oct 21, 2022 6:29 am
Thanks Husky,
That works for me :D
Re: [SOLVED] How do I hide the marker (tiny circle and crosshair) that remains after moving the last object?
Post by Husky » Fri Oct 21, 2022 6:34 am
You're welcome! :wink:
zfgo01
Post by zfgo01 » Sun Nov 13, 2022 7:11 pm
That works! Thanks. I finally am able to get that obnoxious little sucker out of the way.
g
Post by CVH » Sun Nov 13, 2022 8:33 pm
@ zfgo01
That 'obnoxious little sucker' is a key functionality of QCAD.
Mostly it is at the last used coordinate.
Relative coordinates are based on that.
It also serves for snapping perpendicular or tangential.
:wink:
It is not saved nor printed.
