opennurbs: IsUnsetPoint has been removed
Thierry Th
Post by Thierry Th » Sun Apr 23, 2023 4:53 pm
Compiling QCAD against opennurbs v7.11.21285.13001 aborts with the following error:
math/RSpline.cpp:1051:11: error: no member named 'IsUnsetPoint' in 'ON_3dPoint'
    if (p.IsUnsetPoint()) {
math/RSpline.cpp:1916:5: warning: 'qSort<QList<double>>' is deprecated: Use std::sort [-Wdeprecated-declarations]
    qSort(keys);
/usr/local/include/qt5/QtCore/qalgorithms.h:188:1: note: 'qSort<QList<double>>' has been explicitly marked deprecated here
QT_DEPRECATED_X("Use std::sort") inline void qSort(Container &c)
/usr/local/include/qt5/QtCore/qglobal.h:294:33: note: expanded from macro 'QT_DEPRECATED_X'
#  define QT_DEPRECATED_X(text) Q_DECL_DEPRECATED_X(text)
/usr/local/include/qt5/QtCore/qcompilerdetection.h:675:55: note: expanded from macro 'Q_DECL_DEPRECATED_X'
#    define Q_DECL_DEPRECATED_X(text) __attribute__ ((__deprecated__(text)))
and this is normal because IsUnsetPoint has been removed.
Re: opennurbs: IsUnsetPoint has been removed
Post by CVH » Mon Apr 24, 2023 6:14 am
OK, noted, but can you elaborate on what that has to do with QCAD CE.
And why not use the included opennurbs version:
https://github.com/qcad/qcad/tree/maste ... /opennurbs
Just curious. :wink:
Used in RSpline::getPointAt to verify the returned point p on a spline at given position t(0..1).
If IsUnsetPoint is deprecated then I presume all are not 'unset' and thus none are invalid.
And we could return the valid vector RVector(p.x, p.y).
Just a shot in the dark, I know nothing of this stuff. :lol:
Thierry Th
Post by Thierry Th » Mon Apr 24, 2023 5:15 pm
Thanks for your reply.
Actually I'm using the port of QCAD on FreeBSD:
https://www.freshports.org/cad/qcad
I'm not the maintainer of this port, but I know the ports system: when possible, it is recommended to not use the bundled dependencies (like opennurbs), but to prefer depend on a separate package:
- the pre-requisites packages have a maintainer, if some patches are needed they are already applied, and they should be fixed quicker in case of problem;
- they may be shared between several apps.
Post by CVH » Mon Apr 24, 2023 8:44 pm
Thanks for the link but I see some duality ...
The site states "QCad is a professional CAD System" but it is not QCAD Pro at all.
Please read the script headers:
* QCAD is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Funny to see your own contributions back on another site.
FlexPainter, InfoCentroids, DrawFromCSV among others. 8)
Then again ... The first two are definitely QCAD Pro features. :lol:
And the third will not handle fit-point splines.
And all the pat files by John and the themes by Pete ...
Right: Open source.
