QCAD crashes on start
mmalavolti
Post by mmalavolti » Thu Mar 14, 2024 7:13 pm
I have QCAD Pro 3.24.3 on Ubuntu 22.04.4 LTS.
Now when I start it I get this error:
QCAD version  3.24.3
./qcad: riga 9: 48577 Errore di segmentazione (core dump creato) LD_LIBRARY_PATH="$DIR" "$binary" "$@"
QCAD has unexpectedly quit.
I had to remove lines in the log due to your antispam policy.
Can you help me in how to solve this problem?
I have tried 3.29.4 trial and it works.
Thanks in advance,
Max
Re: QCAD crashes on start
Post by CVH » Fri Mar 15, 2024 6:05 am
I think you might try the Qt5 package:
Similar reports, similar solutions:
https://www.qcad.org/rsforum/viewtopic.php?f=34&t=10622
https://www.qcad.org/rsforum/viewtopic.php?f=34&t=10370
Or you might try resetting your configuration:
