Re-OPEN SOLVED: Addressing regular Qcad scripts
Discussion forum for contributors and developers who are using the QCAD ECMAScript development platform or the C++ plugin interface or who are otherwise looking to contribute to QCAD (translations, documentation, etc).
Post by CVH » Wed Aug 28, 2019 3:35 pm
Andrew,
To make use of the addSpline simple API I included simple.js in my script.
Just as prescribed but I had to use 'include("scripts/simple.js");' ... and more
I had to put the physical scripts under the Qcad scripts folder.
Along with the script files: simple_create.js, simple_info.js, simple_input.js, simple_modify.js,
simple_transaction.js, simple_view.js.
And those are simply included by simple.js as a plain 'include("xyz,js").
Something similar is true for sprintf.js.
All in contradiction with eg. library.js that used to be not included in my script with no file present.
Or the inclusion of EAction in Misc.js as 'include("scripts/EAction.js");' with no file present.
I presumed that all scripts where present as compiled versions in a Win installer.
It seems that this is made straightforward for some but not for all.
OR
I am completely missing something here.
Regards
QCADpro 3.24.3.10 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Re: Addressing regular Qcad scripts
Post by andrew » Wed Aug 28, 2019 8:32 pm
should work (and does work here). No need to copy any files into your QCAD installation. All scripts are compiled into the qcadscripts plugin.
Post by CVH » Thu Aug 29, 2019 11:28 am
SOLVED
Well, I have some well documented 'Include structures trees' in the top of several experimental scripts.
And their only purpose was to have an overview where what is included, literally how and if it was/is not present.
If they were not present and an error was trown at load or at runtime the appropriate files where sourced from Github.
Every update since ...
viewtopic.php?f=8&t=5624&p=20916#p20925
At the cost of countless hours of restarting Qcad over and over again.
Without, with and again without the debugger.
In the last year I updated regularly.
A few times I did a deïnstallation and a 'clean' install for what it's worth.
If that did not solved the issues in the past, and as a system restore from over a year ago is out of the question...
I have decided to wipe Qcad and any traces of the system before a reinstall.
I can't advice anyone to try this on a win system without having some experience in this process.
Any fault in this may irreversibel corrupt the complete system.
Also recommended is having a second system to source the internet when you get stuck.
I've added a verbose summary for the most daring.
Andrew, maybe you could update the header of simple.js and set the correct include text.
Thanks,
Regards
Wipe Qcad from win.txt
(1.98 KiB) Downloaded 234 times
Re: SOLVED: Addressing regular Qcad scripts
Post by andrew » Thu Aug 29, 2019 11:34 am
Hmm.. uninstalling ("wiping") QCAD is as simple as deleting its installation folder (that is one single folder with all its contents) and that's it.
Resetting the configuration is slightly more involved to delete the file QCAD3.ini:
I'd certainly not recommend anyone to go through the ordeal described in the above document ;)
Post by CVH » Thu Aug 29, 2019 11:40 am
It's the only thing that did the trick so far.
Lets hope more of my issues were solved.
Regards
Post by Husky » Thu Aug 29, 2019 7:24 pm
I second that!
Re: Re-OPEN SOLVED: Addressing regular Qcad scripts
Post by CVH » Sun Sep 08, 2019 6:31 am
Re-encountered it with this topic:
https://qcad.org/rsforum/viewtopic.php?t=6552
This time I know exactly what I did: it only took me 35 min
And my memory is not that bad yet.
Downloaded most recent zip with Qcad master from Github >> Data drive / Copy downloads
Expanded under Copy downloads/master files.....
Created subfolder C:\Program Files\QCAD\scripts\Modify
UAC >> yes, I'm Admin
Created subfolder C:\Program Files\QCAD\scripts\Modify\Scale
Copied Scale.js from master to C:\Program Files\QCAD\scripts\Modify\Scale
Copied and renamed to Scale.js.org
UAC >> yes, yes, I'm Admin
Implemented change to Scale.js with NPP
Save >> Admin mode? yes, ... (NPP reopens in Admin mode)
Save
Started Qcad in debugger mode
Errors with associated files so closed Qcad
Tried to no avail some different include's eg. without path
Copied and renamed to Scale.js.new >> UAC...
Copied complete master Scale folder to C:\Program Files\QCAD\scripts\Modify >> UAC...
Deleted original Scale.js and renamed Scale.js.new back >> UAC...
Implemented Optionbutton in ScaleDialog.ui with Qt Designer (5.11.1)
Qt Designer can't write back to protected OS portion
Saved temporary on datadrive, this messes up the paths of the pics
Copied over to C:\Program Files\QCAD\scripts\Modify\Scale >> UAC...
Corrected pic paths with NPP
Saved (is in admin mode)
Implemented Optionbutton in Scale.js with NPP
Errors with associated files in Modify folder so closed Qcad
Copied all 6 files from master Modify folder to C:\Program Files\QCAD\scripts\Modify >> UAC...
works as a charm
Again I have to have a copy of all files involved under Qcad
Help!?
Return to “QCAD Developers and Contributors”
